Hey guys
At the moment im trying to piece everything together to get my car back on the road
I just have a few questions regarding a few things i need to do or want to do
First being is it possible for me to put a series 2 grill on a series 1 set of lights?
Second is how the hell do you get the fender/guard off when the last 2 screws situated on the bottom of the car arent moving?
i have got the other screws out but the last two wont budge. Ive tried WD-40, screwing it out, hammering it out, drilling though it (wouldnt go too deep). I need to keep the original holes aswell to put the new fender/guard on. Has anyone experience the same problem? My guess is it wont move because it has been on there since 1993 and hasnt moved one bit since then. Also the factor of the screws being pushed in isn't possible because the accident didn't damage the bottom of the guard at all.
What you guys think?
Lastly how the hell do you take the headlights out when the bolts are situated in the most hard to reach places? I have tried ratchet set etc. Please let me know if you have had previous experience.
:D cheers guys
https://www.sau.com.au/forums/topic/329288-general-questions/
:D cheers guys
u dont need a ratchet set to get them out just a phillips head, u need to unscrew it from underneath the car leaving the bracket still connected to the bottom of the light (2 screws each bracket)
i have done it a few times
what area u at, if close i might be able to drop in after work n show u tomoz
thought so
someone at a particular japanese parts store had told me that there the same and when i put the bonnet on my series 1 guard it had a normal size gap. But after putting the series 2 guard on the other side the gap was very minimal.
cheers anyways guys
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
