Hey guys/gals,
Up for sale a some various parts off my r32 gtst.
- R32 GTS-t Standard turb0 - MINIMAL shaft play $160 neg
- This turbocharger made a touch over 165rwks when it was on my car, ran 10 pound.
- R32 GTS-t standard side mount inter cooler with piping, $75 (very neg)
- R32 GTS-t aftermaket suspension set unsure of make but was in inpressive working order in my car, very good ride aswell as good cornering. $100
- Standard R32 GTS-t rear Camber Arms $50 (neg)
- Aftermarket R32GTS-T LED REAR Taillights
Located in Adelaide (postage will be considered but at buyers expense)
Please dont hesitate to pm me if your interested i check back on the site regulary so will respond imediatly.
Thanks Guys
https://www.sau.com.au/forums/topic/329382-r32-parts-sellout/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
