Hey guys, needing some advice on a leak i've got at the moment on my 32.
I noticed it yesterday when i saw coolant running along my driveway, its not leaking alot but enough. Fairly sure its only leaking while the engine is on.
It is coming from the back of the engine bay somewhere behind the motor, and running down onto the passenger side of my gearbox.
I have pulled off the two heater hoses behind the engine to check them properly and replaced clamps even though they were all fine.
Now im stuck, its obviously got to be something lower than those hoses, is there any more hoses etc underneath those i should look for as its nearly impossible to get down there.
Any help would be great,
Cheers
Steve
https://www.sau.com.au/forums/topic/330454-rb25-coolant-leak-problem/
could be the turbo water hose, under neath the intake there is a 'L' bend near the stater motor! it happemed to me on my rb25det it was a pin hole and it would squirt up on top of the gear box and run down the passanger side
hey mate, i had a problem with a coolent hose leaking bihind the motor.. (i have an Rb25 in my R32 aswell) you could just see it squirting outta a pin hole!. i could not reach iit by hand at all..
how i fixed it was.. taking starter motor off! pretty easy 2 or 3 bolts, then with one hand sliced the busted hose off. then bought some new Heavy duty hose from gibs trucks and 2 new hose clams. and with only one harm fitted it all up! took some time.. but was easyer then taking off the inlet manifold!
hope this helps!
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
