http://www.skylinesaustralia.com/forums/Rb26-t320872.html
Well theres a link for a running engine if someone wishes to buy both n do the swap.
My engine has the 34 N1 turbo's n ive got the power fc n other stuff needed for a retune ready to go.
it will cost you a good 3-4k is it going to be worth it for you? thats a second rebuild this car is going to owe you too much in the end just try and sell it. (well if i were in your position i would) you can get a r32 gtr these days for 13k and if you personal import 10k so yea do your maths to see if its worth it goodluck with all
If i bougt another gtr for 13000 id be back to square one with a standard car. This car already has everything i need. I can get away with it for around $2000
do what u want mate, ur life, ur money, ur car. good luck with it :D
  • Nope 1
  • 6 months later...
Cars back up for sale guys.
Also plenty of spare parts Including a set of new Rota P45's with Kumo KU36's
Power FC with hand controller
Engine dampener
Standard suspension
plus more
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
