Hey all I bought these a while ago from a member on the forum. I have since sold my GTR and have no need for any of this.
HKS external gate
45mm entry with 50 mm exit
Comes with manifold flanges and exhaust port second hand good working order
HKS T04e
60mm comp wheel inducer a/r 72 front housing
65mm ex wheel t4 flange a/r 90
Comes with dump pipe
these items were part of a t04e turbo kit to suit a gtr ( 500 hp capable )both good working order no shaft play on turbo and wastegate is fully functional.
Xforce rb26 exhaust manifold t4 - Suit rb26 with allowance for external gate.
Twin entry afm to turbo pipe
Price: $1100
PM me here if interested
how much you looking at for rb26 head minus the full set of injectors mate??
is it stock head? ie no porting or cams
I have not had the turbo fitted since I bought it (2 years ago). Whole package was bought off this forum. Previous owner had the turbo checked out by Factory R.E and it had less than 1mm play side to side (which should be gone once it gets oil pressure), and no shaft play when you push it in and out
Cheers
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
