http://www.horsepowerinabox.com/HPIAB2/prod641.htm
I might order one of these tomorow what yas think of price and size I don't care about lag
Do not buy that one.
If you are going down the route of a GT3076 then you will need a T3 flanged (not T25 SR20 type exhaust flange).
I would sit down and have a really good think about what you want out of a turbo before acting as you will save money in the long run by thinking it through.
I am not a fan of the turbine housings that bolt up to the stock dumps as I have never seen them allow the full potential of a 76mm compressor.
If you go down the path of a complete Garrett unit then you need to consider dump, oil/water lines, intake changes and you will need new injectors even with the correct HPIAB GT3076 with T3 flange there are still issues with oil/water line and intake changes.
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5379999
If you're thinking of that exact one in the link, then don't do it. It's in a T25 flange and is made to fit SR engines.
Look for one that is in T3 flange :D
Edit: Dammit, beaten :)
Edited by d1_drifter
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380002
i no its not that one i need but morrie at from that place says he has the one for rbs and the oil n water lines arnt much of a hassle. and im doin the exuast to suit so that doesnt matter.
i was gona get him to fit it so he can deal with it but now i have the motor striped down i was gona do it myself and just give it to him to tune.
i want to spend about $1600 to $1800max just on turbo.
if yas wana thro ya sugestions down go for it. just remember lag doesnt bother me, so must be in the 30s
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380071
cars got 200wkw now with fmic pod no rear muffler and nistune set at 14 psi (droping to 9)
want to get 250wkw with
new turbo $1600
fuel pump $150
afm $200
exhaust$800
if injectors can handle it il do them later and what ever else to get 300wkw
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380105
Ild be happy with 270 to 280 if that's about all that turbo can make I'm just Gona run it at what Eva the injectors can handle for now untill I get more coin. The exhaust and other bits are Gina send me broke for a while
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380898
Trying to pay mortgage on one wage at moment so budget isn't looking good for injectors.
Has anyone got sum of that metal paste stuff I can steal so I don't have to buy a $50 tin of it?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381030
You won't need the afm if you don't change the injectors. Save the money for your turbo - total installation costs will be more with bits and pieces. Also I think fuel pump will cost more than $150 and afm will be $300.
Just do the turbo and fuel pump for now. What are you using for boost control?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381108
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
