When i bought the car , the bloke said that he had the car on a dyno for 4 hours.
I was wondering how often a car should be dynoed, it was last on a dyno on 24/10 2001. My car is running great but VERY VERY RICH, which is supposed to be a safety thing.
Should i get the car on a dyno to see how things are or is it a waste of money & time.
https://www.sau.com.au/forums/topic/33131-how-often-to-dyno-tune/
if it is running VERY VERY RICH, then that is sort of an over kill.
I think that a safe air:fuel setting is 11:1 or even 11.5:1
above that would be too lean for constant on boost type driving.
My R32 GTST was at about 12.3:1 on MAX load when on the dyno but it never had a problem cause it would only be on that for a few seconds at a time.
If your car is as rich as you make it out to be, it would be effecting performance, it would be fouling up your plugs and oxygen sensor and you would be getting SHIT fuel economy..
The way I see it, you have an R33 GTR.
It is worth what... over $40K??
spending $70 for a single power run on a dyno would show you HOW rich/lean your car is...
then I believe the most expensive I have seen is about $110 per hour for dyno tuning at like Croydon Racing Development (CRD) at Silverwater.
If you have a POWER FC or some sort of aftermarket programable ecu, then it wouldn't even be more than an hours worth of tuning..
I think for under $200 you could get your car tuned to perfection and still be safe.
As for how often you need to get your car dyno tuned, once it's set, you shouldn't have to retune unless you do another power mod.
say you went and got it tuned and then later found that you only had a cat back and got some dump/front pipes which resulted in some more boost and power, you would be wise to make sure that this hasn't put your A:F ratio out of whack...
NOTE: the above is my opinion.
Some people say that the optimal air:fuel ratio for a turbo car is 12:1....
But I personally would prefer to be a little on the saefr side of Optimal...
Hope that helps..
Pretty much spot on there GTST...
Don't expect to get your car tuned at CRD for any less than $800 though... That's their minimum cost... Jim is an excellent tuner, but quite expensive...
The optimum ratio for air:fuel on any combustion engine is about 12:1 - if you are looking for power.
However, if you run an engine at 12:1 you are looking at over-heating problems, which is why most engines run slightly rich, because with less air in the mixture the engine will run cooler.
You probably already know this!
Thanks for the info GTST, its running too rich , i've alreadly replaced the 02 sensors 2 months ago & i'm not getting too much above 200km city driving. When i give it in 1st gear, off the mark a big black cloud of smoke comes out about 2-3 metres high (like a diesel truck)lol.
The car has a lot of mods ( standard internals i think), it was taken to the HKS workshop in Japan before it got imported to aust & it only produces 245awkw, but it does feel quick, people on this forum seem to be getting that on stock turbos & with less mods?
I've got to take it to eastern creek for some times in the near future.
200km to a tank??
Jebus man...
you weren't kidding about it being rich..
I would definitely spend a few hundred tuning it..
that's not right..
I'd also recommend a spark plug change after the mixtures are corrected..
I think that on your baseline run, the A:F ratio's will be off the chart.. as in below the 10:1 reading that most dyno's are calibrated to.. (I think)
245kw at the wheels! I love rb26s.
If you're blowing that much smoke and getting such bad milage i reckon you need to have it looked at. Theres probably another 20kw hiding in there easy :)
If it is only blowing smoke when you put your foot down then it may just be the pump settings are out of whack and it needs a bit of road tuning to iron out drivability issues.
Still talk to a tuner, dyno time is a great way of seeing what your car is doing anyway so give it a go
"Don't expect to get your car tuned at CRD for any less than $800 though..."
My car (the magna, not the FD, obviously) was on the dyno for several hours (quite a few actually) and he charged me about $200... (actually, that covered install too...)
It was a sponsored car (unichip sponsored, among others) and I was giving him a good plug on my website though!
Nice guy - and a great tuner!
Definitely expensive - but you get what you pay for
It only blows smoke when i'm taking off & a few seconds after reving the engine (stationary). The dyno tuner said that he had noted it down when the car was last there.
He said that there was a air flow metre problem caused by a bad compressor surge. He said that some one had modified the turbo housing or the turbo wheel.
Where do i start to correct this problem. He said that he doesn't deal with those type of problems.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
