post-73733-1281093478_thumb.jpgpost-73733-1281093388_thumb.jpgpost-3069-1125383374.jpgpost-73733-1281092996_thumb.jpg
up for sale is my 1993 r32 gts-t it has served me well for the past six months i have owned it getting me everywhere i needed to go i am selling it because i am moving overseas and need all the money i can get.
  • hks b.o.v
  • front mount intercooler
  • lower hks springs will come with car
  • pod filter
  • oil catch can
  • boost guage and water temp in cabin
  • 11psi actuator
  • turbosmart manual boost tee set at 14psi
  • black s15 rims
  • NOTE THE CAR WILL BE SOLD WITHOUT ROADWOTHY AND REG AS ALL THE AFTERMARKET PARTS HAVE TO BE TAKEN OFF TO OBTAIN A ROADWORTHY CERT AND IN DOING THAT ID THEN HAVE TO GO ON THE HUNT FOR ALL THE STOCK PARTS AND I DONT HAVE THAT TIME SPARE. ROADWORTHY MAY BE NEGOTIATED UPON DEPOSIT. PRICE $10.000 o.n.o call me if you have any enqirerys blake 0406484784
https://www.sau.com.au/forums/topic/331941-for-sale-r32-gts-t-1993/
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
