My stock OEM grill is for sale including Nissan badge as I have upgraded to one of the new gialla grills from the states.
OEM grill is perfect except for one broken clip on the bottom which I broke when taking out, but should not make any difference when fitting as there are 3 other clips. One of the pictures below shows the broken clip.
$100 and willing to ship at buyers expense.
Located in Sydney.
https://www.sau.com.au/forums/topic/331951-fs-stock-oem-grill/
  • 2 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
