my bad- maybe his ride actually does have that kinda power (impressive but unless it was on the dyno id remain skeptical - did they publish dyno results anywhere?)
nfi why they interview the kids, tho the one with the breaking voice - that cracked me up
didnt see SAU in that video - kinda disappointing
-D
Previously they used to post the dyno results on the autosalon website but i couldnt find it on this years results.....they had a big screen near the dyno which showed the power outputs......
  • Replies 63
