MV automatics shift kits are the best in aus lets face it!
im going manual... so its a great opportunity for someone interstate to save them self the effort of installation.
i paid 600 or so for the install about 6000ks ago... have receipt here.
id say it will be around the $100 mark to send it interstate.. im in adelaide
will hunt around and c what the going rate is....
might be interested in an r32/33 gtr gearbox if thats what it comes down to!
Edited by chef_stagea
https://www.sau.com.au/forums/topic/332338-eoi-s2-gear-box-with-mvs-shift-kit/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
