Hi everyone apologies if this has been asked but ive searched and had a bit of conflicting info!!
Ive got a 2005 Manual Coupe and im wondering how i find out if its a rev up or not.
Some infomation ive found is you can tell by the redline. 6500 - Non Rev Up 7000 - Rev Up. Well my redline is 6800 :P
Also on my dash ive got Rev illuminated,which some sites have said this is only on rev up motors,but some say its just for a shift change light.
Im looking at buying a supercharger from the states and would appreciate someone with a bit more knowledge than me to confirm and if ill have any problems with the kit.
Thanks in advance
Spenny
https://www.sau.com.au/forums/topic/332350-rev-up-or-not-rev-up/
Thanks guys!!
Just one last question then. The guy selling the supercharger says his is for a non revup. Is there any difference in ours to the states in terms of fitting a supercharger???
Thanks again
I believe that the answer you are looking for is in the engine designation prefix, i.e. VQ35DE - non rev-up and VQ35HR being the rev-up version, HR standing for high rev.
p.s. This is only a theory of mine, so if I'm wrong can someone please correct me. :woot:
Hi Thanks for the quick replies.
Im looking at a procharger kit!! Any feedback is appreciated as im still unsure what way to go.
Thanks
Spenny
It should fit, but with Procharger just be aware that it's going to be really loud and whiney. If you're OK with that then it's also reputed to have very good power potential. The other thing to make sure of is that you have proper control of timing and fuel. In order to get a safe and reliable set-up you will also need injectors (480cc minimum) and a fuel pump.
Some kits come with split-timing boxes and do the extra fuelling with an extra injector in the intake tract. Not ideal but it can work...sometimes. Anyway good luck with your install, supercharged VQs are heaps of fun...
It has taken me a year and a half and I only just discovered the shift light on the weekend. It has always been set at 8000 and therefore has never lit up, so after filling with fuel and resetting my trip, I tried to work out what the 8,000 things was. Messed around and managed to change it to 2000 thinking it was some sort of service interval setting and drove off only to find the light start flashing at 1500 and solid at 2000.
It was pretty exciting there for a few minutes, now I've set it back to 6000 and probably wont see it again for 6 months :blink:
Yeah i found it too,i think i lasted 5 gear changes and i was changing it back to 6000 also. Wish i could get rid of the rev illuminated.
It was pretty exciting there for a few minutes, now I've set it back to 6000 and probably wont see it again for 6 months :action-smiley-069:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
