Hi all. So after getting an apexi pfc, and having a chat with a local tuner who I'm going to use, I'm on the hunt for a z32 airflow meter. But I'm wanting to know if they are all the sme? between the non turb, and turb ones, and I have seen yellow sticker ones, and orange sticker ones. Is there anything I need to be weary of? How about the new ones you can buy? i imagine some of them are cheap knockoffs? Or is there little diffrence between genuine and chinese here? Thanks.
You want the Orange sticker one - And you want a genuine one, a fake chinese or whatever one will be worse than standard and you risk damaging stuff. The fakes have very poor workmanship usually - a quick Google search will help there.
Buy from a trusted distributer - Note eBay if you want to be sure.
Also 2nd hand is buyer beware - it may work fine but it may also be crud.
P3140007t.jpg real
fakeP3140006t.jpg fake
Edited by BlueRB240
So definately staying away from the cheap n nasty then. The only problem is I'll probly be buying online, so won't be able to inspect the item b4 hand. Are there any trusted suppliers over there i could contact to buy a new one? There is a supplyer here, but they're asking 500 for a quality new one. And I'm thinking i should be able to find a sharper price. Times not really an issue. Got lots of other parts to sort out along the way. And can anyone clarify, what are the yellow sticker ones? Also, are the vh45, and vh41 airflow meters viable options with the PFC?
Edited by mawzy
