Alot of questions but not alot of buyers; answers to the most common are below
Cams are ground using a master cam, a master cam is like a mold or a die or a guide what ever you want to call it, hks tomeii camtech crow cams all use the same master cam for this profile, one of them or an independant cam grinder designed the cam and sold a copy of the master cam to the others
Performance doesnt soley rely on turbos or cams etc it works as a complete motor to work as a solid unit to gain the most power and life out of all parts
Power range is estimated at 3000-8500+ (depending on supporting modificiations) power rev range will change with adjustable cam gears
I bought these for $750 never used, decided I wanted something a little bigger
As the cams will alter the air fuel ratio yes you will need to remap your computer
For a bit extra I can supply valve springs
Flywheel has never been used, weighs 5.5kg, never been fitted to a car usually sell for $430ish
No stupid low ball offers, im already loosing money on these
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
