Hey guys,
FOR SALE
RB26 Head complete, but cam's and rocket cover removed. easy to reassembly. $900
R32 GTR Gear Box $500
GTR Front Mount $150
2* T28 Turbo's. small shaft movement. $ 100 each
GTR Sump $300
RB 26 Block with craddle ONLY $150
R32 Radiator $80
New Alternator $ 100
I can be contacted on 0410 608 450 for details!! :yes::)
Edited by MattyBoi
https://www.sau.com.au/forums/topic/332931-gtr-engine-part/
how much are the rocket covers worth? i was thinking sell it complete...... i have the twin throttle body aswell
HEY GUYS, I HAVE TROUBLE PM ING, SO PLEASE POST IT OR I CAN BE CONTACTED ON 0410 608 450 ANYTIME!! :D CHEERS!
https://www.sau.com.au/forums/topic/332931-gtr-engine-part/#findComment-5400287
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
