hey guys,
i might have some bad news but i'll ask you guys anyway...
last night after re-bleeding front brakes i saw a small bit of oil underneath the car so i degreased it and washed it down.
after doing that i did the normal things like checked oil and radiator and found the small bubbles coming up while it was idling, then like a white milkly stuff started to surround the top of the radiator, not alot but still noticable. bigger bubbles from time to time and also when revving the engine to about 2k the coolant level lowered abit.
doesn't seem to be overheating at all nor driving any different...
dont' think i've missed anything.
any input would be great.
curt
https://www.sau.com.au/forums/topic/333128-s2-stagea-with-coolant-issues/
If you have the cap off and rev the engine the coolant level will commonly go down and return to normal when you stop. Watch for the leak to reappear. Bubbles and milky stuff bit of a concern. Try to get your colling system pressure tested (any radiator shop should be able to do it - its a 5min job.
Liek Kiwi said, coolant level varying on engine revs is normal, as your waterpump is 'pushing' (or trying to) more coolant into the block. The bubbles and milky residue is a concern. It does sound like you've got a blown head gasket unfortunately. :)
Pull your dipstick out and see if you've got any trace of a "chocolate milkshake" there. This will show coolant mixing with oil. If no oil, only bubbles, then its coolant leaking into cylinder.
If you can change the head gasket yourself, you'll save a big bundle.
Don't panic. Are you losing water, overheating? Get the pressure test done and if there is no negative result just keep on driving while looking for any more symptoms. If there is clear evidence of water in the oil or vice versa or if the pressure test shows system not holding pressure then you may need to look at pulling head off.
losing alittle water that i noticed the other day.. but i had the top tank replaced about 2-3 months ago, so it may have not been bled right.. it doesn't overheat.
i'll have to take it down to the radiator place on my next day for them to check it out.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
