hey guys, just got my r33 gts T,
car starts but dies at idle after like 1 second!! all this happened after i redlined it in 2nd gear (testing how fast it would go in 2nd.. 110kph) anyway after this car struggled to accellerate.. even with foot 2 floor the car would barely move.. was luki 2 make it home.. now it wont idle for long at all ( 1 second)... any1 offer any advice? would be greatly appreciated
https://www.sau.com.au/forums/topic/333208-car-dies-at-idle/
could be a number of things. possibly a big vaccuum leak. have you opened the lid yet to check for anything obvious?
check all the vaccuum lines coming off the intake plenum make sure they'r hooked up. if they are then just look at all other lines/pipes you can see and make sure. physically grab any joins in the piping to make sure they'r secure and not loose.
had this happen the day i got my r32 and it was after i'd wound the boost up a little and an intake pipe had popped off because some muppet hadn't secured it properly
nah its all together stock as car with pod fliter... mate rekons its aac valve thing at end of engine.. idk.. worst problem lol
