I want to get 5 spokes for my car so selling the wheels on my car at the moment. They are 17" Weds Kranze ERM. Tyres are 235 45 all round and have been on less than 1,000km but they aren't anything special, just cheapies. Rears are slightly stretch
Unsure of offset and exact width at the moment but I will have a look when I take the rims off and take decent pics of the rims. All have slight rash so they are definitely not a perfect set.
Only pics I have at the moment are of the car but u get the idea of fitment and looks. :) Front has 25mm spacers and rears just 5mm. I will get a close up pics and more info on offset and width during the day tomorrow. Thought I would just get the ball rollin'.
I'm located in Adelaide. Gepps Cross during business hours and Gawler after or weekends.
Looking at $750 ono
Ph: 0433603333
https://www.sau.com.au/forums/topic/333598-17-meshie-wheels-fairly-new-tyres/
Sorry for the delay, had to raise my ride height and dinner!
Okay, nothing on the inside to say width or offset so measured them my self. Front are 230mm (9") wide (outside to outside of rim) and are +32 offset. 147mm from inside of rim to inner mounting face.
Rears are 256mm(10") wide with +37 offset. 165mm from inner rim to inside mounting face.
I'm not sure if that's how u calculate width and offset, but I have give u the measurement incase I am wrong.
Pics now attached
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
