  • Replies 48
I have a question, this was posted on another forum:
quote:
Originally posted by rbsileighty
HKS said that BB turbo's should spool about 500 rpm quicker than a similar sized non BB turbo when I spoke with them on the phone.
Sounds to me like they wanted you to buy a ball bearing turbo. Ball Bearings do not spool the turbo at greatly lowered RPM. The exhaust housing A/R and the turbine wheel (stage 3 vs. stage 5) determine the spool characteristics of the turbo.
ball bearings increase the transient response of the turbo. An example would be that if you are already in an rpm range where full boost is reached, from the time you floor it to the time it is at full boost would be sooner on a BB turbo.
A turbo without ball bearings will spool at almost the same rpm as a turbo with ball bearings if the turbine and compressor specifications are identical.
-Jay
Who is right, this guy or HKS?
https://www.sau.com.au/forums/topic/33365-t3-turbo/page/3/#findComment-685075
I tend to agree with this person to a certain extent. Just because a turbo is BB doesnt mean that its going to be responsive. The size and material of the wheel, the pitch of the blades, the A/R of the housings used all play a much bigger part in the characteristics of the turbo.
I started a thread that got erased with the backup a few months ago "BB VS Bush turbos"
My opinion only and many will disagree is that BB add more to the durabilty/reliabilty of a turbo then to its performance. Looking at bearing in general, not just specific to turbos, the two different types behave differently.
Basically any sort of bearing's purpose is to overcome friction. Now there are two kinds of friction, the static (stationary trying to move) and the kinetic (once its moving)
The resistance for something to move is always greater then once it is moving, so the kinetic friction is lower then the static friction. And whilst the use of ball bearings lowers both the static and kinetic friction over a normal bush bearing, its most dramatic effect is on static friction. How many turbos spin at idle...
The BB turbo is superoir as it can withstand higher axial loads, isnt so sensitive to oil pressure/temp/quality, and typically it turbine/compressor uses superior aerodynamics/materials. That said many factory performance cars today still use bush bearings and are covered by warranties, so its safe to say if the reliability aspect of the modern bush bearing turbo was too big a concern then it wouldnt be used by manufacturers like Porsche.
So does a BB turbo lower the boost threshold and lag of a turbo, yes, but i fell its not as pronounced as ppl believe. It would be interesting to see someone build a turbo using the exact same wheel/trim and housings, only to used different cores, one plain bearing one ball bearing. I suspect ppl would be surprised by the result.
https://www.sau.com.au/forums/topic/33365-t3-turbo/page/3/#findComment-685229
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
