r32 drivers side guard in primer ready for paint, perfect condition has all the mounting points
$ 90 or nearest offer MAKE A F*CKING OFFER
r32 front strut brace, in good condition, used only once on a car for like 200 km if that then the car was stripped
$120 ono MAKE AN OFFER NEED IT GONE!
r32 cluster surround, manual type m in good condition all mounting points are there
not sure what they re worth but i know they re always cracking $120 ono THROW US AN OFFER now $90!
r32 cluster surround, auto type m in good condition all mountin points are there and not broken
$80 ono THROW AN OFFER now $50!
r32 drivers side indicator, clear and maber, has crack 30 posted
180sx rear reo bar, in perfect condition $70
hey guys
up for sale are front pair of type m seats out of a r32, they are reclinable, bolt straight into s13, very good condition, no rips or tears they just need a clean
has 3 adjustable knobs, so it hugs you, the bottom half can move up and down, gangster...
$200 ono, throw us an offer
pick up only, dicks to postage
pick up from western suburbs melbourne
pm if interested
or call 0413 926 794
apexi rear strut brace for s13/180sx, has been on my stationary car and thats it so it hasnt been used for driving purposes yet, carbon fibre finish and anodised red bracing $150 ono pretty much brand new condition
stainless steel manifold for sr20det blacktop and redtop
has flange for external gate
in brand new condition has not been used
have been told flange is t3/t4 but not 100% sure
$300 ono i will post, offer me a price MAKE OFFERS FOR THIS ITEM NEED IT GONE
up for sale is a set o toe arms i purchased off pnk180 a while back
in good nick and in working order, have no use for them
toe arms in very good nick with good bushes also unknown brand
anyway here are some pictures
170 DELIVERED MAKE OFFERS
up for sale are my cams,was in a redtop, he had it in there for 2000km if that until he copped a defect and epa and i bought the motor
these are the REVISED VERSION and they have bigger lift than normal step 1s I.E THEY COST MORE than stage one
specs are:
Intake:
256 degree/duration 11.5 lift
264 degree/duration 11.5 lift
they are a lot higher than stage one hks cams, they are the "REVISED VERSION", in immac condition
wanting 700 now 650! POSTED or nearest offer MAKE AN OFFER NEED REGO MONEY! MAKE OFFERS NEEED IT GONEEEEEEEEEE
f**k IT NOW $600 POSTED
pics
s14 series 2 front bar fog light with loom and mounting points, only rhs (drivers side), good for those who are missing one, perfect condition $75 posted to your door MAKE AN OFFER NOW $40 POSTED
up for sale is r32 front wishbone setup, both left and right both are straight, both come with control arms, new bushes for the wishbone, bolt straight in, also has rotors, jst no brakes and comes with hub of course, everything in good condition, came off a running car, no bearing noises etc et
SEPARATING TELL ME WHAT YOU NEED
have a pair of nexen 3000 radials for sale 235/45/17, local only, very good tread, bit of camber wear, only driven for 3000km still very new, have a geezer at the pics
price is $200 for the pair MAKE OFFERSSSSSSSSSSSSSSSSSSSSS NOW $150
r32 rear bar does not come with reverse lights as on has broken only rhs reverse light is available
$70 or nearest offer YES IT IS A TYPE M REAR BAR does not come with reverse lights $50 !!!!!!
r32 boot TYPE M in navy blue, comes with lock and is in perfect conidiotn has type m rear spoiler in blue as well
$70 or nearest offer MAKE OFFFFFFEEEERRRRR NOW $50
western suburbs melbourne pm or call 0413 926 794
  • 6 months later...
In need of this:
If you could do just the left for cheaper, that would be great
pm me please
Alex
In need of this:
pm me please
Alex
And i would like the right hand side, price ?
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
