Hi everyone
I have the following items for sale,
1, R34 GTT Bilstein shock absorbers with Kings spring. Those shock are in good condition; no leaking. Selling it due to upgraded to coilovers
Price $350+postage
2, H1 size 8000k HID light bulb, a pair. Those bulb are brand new and was order for my car but won't fit in the xenon head light
Price $35 with postage
3 H4 size 8000k HID kit (with High and Low beam). They are 90% new just test fit the bracket into the car, light bulb and ballast have never been use. This kit is only use as a business promotion.
Price $145 with postage
Items are located in Brisbane, if anyone interest please send me a email [email protected] or send me an SMS 0424459279,Thank you
https://www.sau.com.au/forums/topic/333973-some-new-and-old-parts-for-sale/
No they off my 34, I believe they are the optional upgrade for my car, because there are some jap writting on the shocks. I am not sure about the model number but I find a set of number under the front and the rear coil.
Front: E4-FT2-Z003A01
Rear: E4-FT2-Z007A00
More info the shocks are traveled about 50000k and the Kings spring were in the shocks around 48000k, although it had done a fair bit of distance but the mechanic said they are still in good shape. All the inspection and installation were done by Centrax Brisbane, the Endless official disributor.
Hope it helps!!
I take it they arent the sydneykid bilsteins? what are the model numbers on them?
Cheers
I mean the kings springs were installed at 48000km and the total of the shocks had traveled about 50000km.
Hope it helps!!
Do you have the standard springs for the shocks? any idea if they are lower than standard suspension (with the original springs)? I'm interested but would rather have the shocks matched with the springs that they were matched to
guys bilstein shocks now $320!! Please need them go away
and Just find out the hid kit is missing one of the bracket, it will be $80 for the set
  • 3 weeks later...
  • 5 months later...
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
