Oil pressure switch is to let you know when your oil is low
Behold, the fabled $100 (S)Exa, the missing cylinder is injector related, I can't hear a pulse and the loom seems shabby (loses another cylinder on moving) OK time for some TLC and boost!!!!
Hey Dan, how's Project EXA coming along?
somehow that exa looks kinda tuff :(
anyone on here know the thread size of a T3 oil drain? RB25 turbo in other words, getting hole of some speedflow fittings with gates hoses to replace the radiator hose (yes im nervous too)
have noticed lately that i seem to be getting a weird noise when i give it a slight kick in the guts. usually happens when im in 2nd, mate says it SOUNDS like pinging, i sorta had the same idea but im not sure.
yeah am still trying to get hold of a stock GTST ECU to start with. as i think i might have said before, i have noticed it to be running leaner, but your right i really should get it tuned anyway.
have got all my new speedflow bits on now :D just waiting on an airbox and SMIC.
not sure where i should take it to get tuned tho...i live 3 hours from melb
Yeah sounds like your on the right track then :D Change coilpacks too while you're at it... i lost another one last night, haven't had the chance to get my splitfires in. I later lost another 1 or maybe 2? lucky i was 9kms from home RACQ towed it without it putting me outta pocket.. but save the headache and get them done too if you haven't.
is the R33 GTSt ECU remappable?
yep they are,
toshi can remap them, he done mine im very happy, myne doesnt ping now and all the hassle are gone,
he can also sell you one of his ecus, for around $600 for a remap and his ecu, or get a link/vipec, depends on future mods
  • 4 weeks later...
yeah fixed the pinging a while back. retarded/advanced (cant remember) the timing 1 degree.
the sparks/packs fixed the spitting problem i was getting when it got hot and i wanted to put the foot down :/ i went SMIC for stealth reasons, cant even tell its there. i can only imagine how much more it would pull with a fmic....
UPDATE: pics!
first two show the engine bay (duh). hoping to eventually replace the blue silicon joiners with black ones and ditch the breather for the correct bit of pipe down to the turbo. also vacum lines are abit messy but should eventually sort em out....oh and do something about that BOV
exhaust is 2.5" catback. obviously the twin tips which i polished, keep attention from the boys in blue to a minimum
LOL operation EXA ended prematurely yesterday when the oil pump let go on the M1, it manage to spray oil over the extractors and "fog" 2 lanes of the highway. Got many dissaproving looks from people, had they been smart they could have easily seen the smoke was billowing from the engine bay not the exhaust.
On zero oil pressure I managed to drive it straight to the wreckers and sold it to them :down:
UPDATE: pics!
I gotta say looks very nice - quite a professional finish. Once you get rid of all the blue bits, should look even better.
On zero oil pressure I managed to drive it straight to the wreckers and sold it to them :)
hahaha nicely done! How much did you get for it? lol
Man that would have been a site! Was it during peak traffic? that would have been hilarious! lol Probably not for you though :)
  • 5 weeks later...
Man that would have been a site! Was it during peak traffic? that would have been hilarious! lol Probably not for you though :P
Yeah about 7:30 so I was less than impressed...the thing that was more annoying was it waited until I was a good 15mins from home and doing 110kmh on the M1, I'd been driving it "sub 100" for weeks and had no dramas, so I thought it was good for a run to the coast. FAIL
quick question; are R33 GTS and GTST AFMs different in anyway? i know theres a diff between S1 and S2s, but the new ECU is from an S1 and its idling real rough, like the A/F ratio isnt right...
basically have bought a GTST ECU to replace the standard GTS one in the hope of getting some more real performance out of it,mainly in the top end.
could it just be a matter of redoing the timing tho? or in need of a remaped ECU
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
