Ramps to drive up on when working on car etc etc $50
Phone/Fax/Answering machine
• Plain paper thermal transfer fax
• DECT cordless handset
• Digital answering system
Click on link below for all features
http://panasonic.com.au/products/details.cfm?objectID=367
Used for less then a month, in original condition. It has been sitting in shed with no use anymore. Also comes with space cartilage as seen in pic
$170 or make an offer
Telstra Phone
Vintage by now but one of the best phones ever
$50 with manual and box and all
Double bed frame
Selling due to upgrade
Make an offer but will put $60 just for the rules
Spalding Punching bag
NEVER used, just got dust on it front sitting there
$60
PRICES ARE NEGOTIABLE BUT NOT ANYTHING STUPID LIKE 1/2 OF WHAT ITS ADVERTISED FOR
LOCATED IN PARKVILLE VIC NEXT TO MELB ZOO
SMS/CALL: 0423 740 146
Still have the car ramps sami?
yes dush it is bro, let me know
hey mate interested with the bed frame.. can it fit into a corolla hatch? or could you deliver to 3132?
its 4 pieces and should fit if there is no passenger. to be honest im too lazy to take it anywhere. also it has supports for the middle part too. i just slapped it together for a pic
hey man how heavy is the punching bag? sms on 0412054982
cheers
d
i'd say just under 20kg and 32 inches
sms sent
hey mate interested if you could dismantle it and give me the measurements of it.. so i could see if i can get it fitted into a hatch..
sorry dude kinda forgot haha
the biggest piece is 95 X 138 cm
2 are that size and 2 are smaller
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
