im chasing a pair of brand new R33 rear camber arms but cant seem to find any dealers here in WA. brands im after are either Kazama, Cusco, JIC, and Ikeya Formula. JPC sells Kazamas but unfortunately they dont have any in stock and will take a long time for it to arrive. anyone knows any places that sells these named brand suspension components in WA?
https://www.sau.com.au/forums/topic/334287-r33-rear-camber-arms/
as mentioned JPC doesnt have any brand new ones in stock at the moment and both Rhys and I have waited too long only to find that until now they still dont have them in stock, Vision R doesnt have any and Jparts also nil or none of the mentioned brands. surely there should be someone here who knows places in WA that sells Cusco, Kazama, JIC and Ikeya Formula suspension parts.
Edited by R33_NICK
I got mine from WA Suspenders, no brand name but they look a lot stronger than some of he branded shit out there (read: much larger tube, they are also one side instead of a loop so I can adjust my traction arms without the coilover hitting the arm).
Look stronger but are they ? I have no namers coming out and going Kazama's
If they break I'll be blaming Bard! The quality looks fine and the tube is nearly double the diameter of most of the others I have seen.
I went to see Matty the other day, but he recommended I went to Danny cos the Whiteline ones they sell foul on the coilover, meaning you need traction arms as well for it all the fit properly.
I have different ones, they aren't Whitelines.
Edited by bubba
just like to add that R32 camber arms front and rear are completely different in design to those on R33 and R34s and maybe even the Stageas. S13s and R32s share the same suspension layout(1989-1993) but R33/R34s together with S14/S15s share the same suspension layout(1993-2000).
If any are chasing brands other than Japanese ones, make sure the material used is made of strong steel like medium carbon steel for example which has better wear resistance and used mainly in forging and automotive components(done some research). normally suspension places should know their products anyway.
keep in mind as well that if your car is to be used for the street, make sure that your chosen suspension arm has dust boots to cover the pillowball bearing from road grime and lots of brands even some Japanese ones like Ikeya Formula have exposed bearings which are ok if your car is dedicated for track use but on the street its a no-no so check before you buy.
anyways, still no one around who knows places that sells Cusco, Ikeya Formula, JIC and Kazamas??
Edited by R33_NICK
Rear are the same dude....well they were for the 10 years i was doing suspension.
Front of 32, 33 and S13 are all different.
Stagea is a bit of a mix match of parts of gtr and gtt/gts.
tho the R32s and S13s rear upper control arms, even the aftermarket ones have a different design where it wraps both sides in an 'O' shape around the strut and the 33s, even the S14/S15s have a bend which also goes around the strut but only on one side in a slight 'U' shape instead but yeah the rear upper link(traction arms) and lower control arm are the same.
The arms you sold me for the 32 went on the Stagea on Saturday, less camber and some toe adjustments have made a rather nice difference!
And yeah Stageas are a big mix and match of parts, each variant (2WD auto, 2WD manual, 4WD auto) seems to be different.
S13 is different front setup to 32 so NOT same layout and S14 is different front to 33 n 34 so NOT same layout ..
32 , 33 n 34 share same rear upper arm ??
Yeah. Camber arm and toe arms are all interchangeable. Some have minor cosmetic differences...but its only visual
The "O" type, or ring type...what ever you prefer to call it, is more due to manufacturer design than vehicle suitability.
Some prefer to make a ring tpye, others have a single rod arm type.
Both do the same job.
The whiteline arms are a great product, however as they wont make the "O" part wider, it is no good with after market shocks as they hit.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
