My R34 NA is starting to be a handfull i need some suggestions or solutions.
1) my Speedo lights are not working......so at night i cant see how fast im going, i have resulted to using a GPS to calculate my speed....., My freind was setting up my stereo do you think he could have cut or diplaced a wire related to the gauges ?, or if its a fuse possibly.
2) My tail lights are not working, my brake lights are.....I checked the fuse box and where tail lights is supposed to be its missing, i dont know why the hell its not there....or why the hell i didnt notice in the last two weeks i had this.....i dont drive that much at night.
Please help if you can. much appeciated.
https://www.sau.com.au/forums/topic/334555-need-help/
Try putting a fuse in there, it's will be the fuse blown or missing causing the problem. If you put a fuse in and it blows then you have a short somewhere.
Have you installed a new CD player recently? There is a wire behind the stereo, which is a earth with ignition off and a power with ignition on or vice versa and is easily mistaken for something it is not. So when this wire is used incorrectly in a cd player install, it blows the parking light fuse.
Have you checked fuses inside the car and under the hood? I know on 33's that particular fuse is in the boot, not inside the car.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5421355
grab a multimeter and try a continuity test in figgerent parts of the circuit.
This will help diagnose where the problem is.
You may have to take the dash out.
It may be as simple as a blown gobe.
This is not a nice exercise.
Best of luck
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422579
yes i did install a cd player, but i didnt drive the car at night untill a couple days later so i wasnt to sure if it was because we played with the wires, when i asked my mate who did all the installing he says it couldnt be. As for the fuses i have changed all of them under the hood after i did it, as for the fuses inside the car they all seem fine, which fuse would exactly be related to speedo lights, because in car lights fuse is working perfectly, so it might actually be a blown globe.....
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422848
1. Firstly, unless your mate is a professional or knows what he's doing.. It's not always best to be cheap and let them have a go.. Can cost more in the end. However i'd check fuses first, then just pull the instrument cluster out and replace a bulb and check if it lights up.. then if that fails, i'd be checking your mates wiring to see if he's done something wrong..
2. Ummm... What is it your asking.. Just replace the fuse if it's missing.. Previous owner prob blew the fuse and took it out and not replaced it
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5422954
He has an r34 to and said his done it a couple of time on his, so i didnt really think to much of it. But i have replaced checked all the in car fuses today and they are all fine...., i guess its time to check the bulb out and im not looking foward to it.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5424214
Why not.. They are easy to get to..
Drop your steering wheel down to it's lowest setting.. Unscrew the surround around your cluster.. Unscrew the cluster.. Pull out and disconnect plugs.. Pull out completely.. Check bulbs..
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5424497
Ok so i took the car to the car electrician and he bascially told me my Alternator is overchaging and around something like 15.5v, above the accepted standard, and he thinks thats what caused my bulbs to blow......, this really sux for a poor Uni student working once a week who wanted to buy pimped out rims and exhaust, he reckons 500 plus labour...... Im thinking i just Buy an original used and reconditioned alternator that these japanese distributing company is selling on ebay and get my family mechanic to give me a family discount lol.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5428569
Problem solved, the lesson to be learnt is if your not a proffesional dont go installing a head unit, apparently its done a little wire frying in the Alternater and fuses and bulbs. All fixed now, but its set me back 350 but its all fixed now new wires, propely soldered Head unit, new bulb in tail light and speedo.
https://www.sau.com.au/forums/topic/334555-need-help/#findComment-5432846
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
