Nismoid the Garret turbine maps actually show the flow rates of the 0.82 GT30 and the 0.63 GT35 as having similar maximums though IMO the GT30 0.82 is the better map , these are with the T3 flanged GT30 turbine housings BTW because the 30 and 35 both use them .
True, they would be close.
However he wants to chase more power so I'd be dubious as to wether it'll get any better.
Going up 100hp in comp size/flow, but down in turbine housing size... Can be a nasty mix.
25psi is still in a respectable efficiency zone of the 82mm compressor. It's out of the most efficient zone but still ok. Peak flow here is caps out at a touch over (60lb/min) , or almost 600hp before hitting choke.
If you use 90% of that flow then it equates to 440 to 450rwhp (assuming you had a larger engine). With 25psi as you stated you should get 410rwhp.
Can a 0.82A/R turbine flow this 410hp? Perhaps. You should check exhaust gas temps as you raise boost.
You probably won't need a bigger compressor just a bigger turbine (and total flow, so you'll also need a GT35 0.82AR). I'd guess a touch under 10% more lag ~400rpm, since you are only changing the turbine side to ~15% more flow. Why not have a look at the maps using true GT35 (3582) turbos and compare.
Edited by simpletool
thats all very interesting, as we all know the old faithful 20 is not the best choice for power, but ive always wanted
to know just how much a 2o can make when its a built engine, i think the limiting factor will be the valves and ports
buts that when the nitrous will come into play.
do you think i should remove the 26 intake and tb's and go for a longer runner and larger 8omm tb option.
i had never thought about a td series turbo, always thought they were a bit old school with response. maybe a BB TO4Z?
How would my 3040 with a 1.06 rear housing compare to a 3582 with a 0.82 in hp rating and response?
I can handle another 500rpm of lag if it means the possibility of making my power goals.
Edited by boostn32
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
