hi wrecking my r33 as i blew my 25/30 and am completly over it :P
parts located northern nsw near byron bay
happy to mail but registered australia post
if chasing anything for a 33 let me know i might have it just not listed
thanks
rb20/25 top mount manifold -
4 bolt external gate to go with manifold with screamer -
PCP660 same as a kkr660 turbo under 2000ks on the car -
70 front 84 rear water and oil cooled
4inch mouth drift pod filter -
braided oil line -
uras front bar made in japan with nismo clear blinkers - $250
D speed side skirts -$200
BN sports rear bar - $200
rb25det series 2 coil packs -$100
rb25det injectors - $80
rb25det standard throttle body - $80
rb25 90mm throttle body (bolts staight onto greddy copy plenums) - $150
rb25det standard inlet plenum converted to forward facing(top and bottom halfs) - $150
rb25det manual ecu - $150
stock corner mount - $50
hybrid front mount - $200
front mount piping to suit forward facing plenum - $150
r33 engine cross member -
r33 power steering res - $50
r33 brake master (abs model) -
r33 brake booster -
r33 steering rack -
rb25 radiator shroud -
r33 front lower control arms - $150 pair
r33 lsd in housing,has a slight wine,would be great to weld and slide - $100
standard r33 rear bar - $70
front and rear seat belts -
r33 gtst after market grill - $50
r33 boot - $100
r33 gtst series 2 rear wing - $80
r33 gtst series 1 rear wing - $80
r33 m spec side skirts - $100
r33 drivers side gaurd perfect nick in black - $100
passenger door complete with glass - $150
drivers door complete with glass - $150
fuel tank - $150
mirrors - $30 each
rear tail lights - $50 each
rear view mirror - $25
rear seats good condition - $80
dash cluster - $100
series 2 front seats with rails - $150
dash facia - $40
interior carpet - $100
rear shelf - $30
door cards - $50 each
all glass offers on each
TRI FORCE ZELDA made by RAYS
17x9 +14s all round
bout 10cm dish - $900 with good tires 80% all round or offers without
clutch brake and accelerator pedal setup - $150
rb25 auto box removed from car at 120xxxks -
will do shell as front or half cut etc etc
anything else off a 33 hit me up for it
Edited by team carefactor
https://www.sau.com.au/forums/topic/334884-wrecking-complete-r33/
thanks
braided oil line -
r33 brake booster -
r33 steering rack -
r33 boot - $100
fuel tank - $150
mirrors - $30 each
rear tail lights -
dash cluster - $100
dash facia -
rear shelf - $30
17x9 +14s all round
bout 10cm dish -
How much is front mount...? have you got 3 inch dump + front pipe..?
have u got the clutch master,slave cylinders,tailshaft,flywheel,pedal kits and lining?lookin to do a conversion for my rb25.if so how much posted to 3030? lemme know 0411795674 cheers
hi wrecking my r33 as i blew my 25/30 and am completly over it ;)
thanks
braided oil line -
r33 brake booster -
r33 steering rack -
r33 boot - $100
fuel tank - $150
mirrors - $30 each
dash cluster - $100
dash facia - $40
rear shelf - $30
17x9 +14s all round
Hey mate r u sellin the inlet plenum show in the picture mounted to the engine???? if not would u take $100 for the other one and be able to post it to wollongong???
brake master $60
inlet plenum in pic on engine already sold
will take $100 for the other modified forward facing one but
sorry cant mail big items like body kit
thanks
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
