Hey ppl,
I am needing some help on how to paint the interior of my 33 (surrounding the dash). What paint do i use, how do i do it, preparation etc.
Any help will be awesome, Cheers.
if you want to paint your dash fascia then youll need the following
plastic primer
desired colour of acrylic paint
clear gloss (if you want a glossy finish)(recommended to protect paint)
any minor sand paper such as 800-1500 grit, id go 1200
keep your primer and colour brands the same if you can
-once you get the rubber film off give the whole fascia a sand ALL OVER the fascia, and when i mean all over i mean every single spot that will be painted other wise the primer may not stick properly and may orange peel up.
MAKE SURE NO RUBBER BITS ARE ANYWHERE
-once sanded give it a wipe with wax and grease remover
-spray with plastic primer slowly, keeping an eye on sections that dont stick properly, if all sticks fine, just give it a couple of layers to make sure every bit of plastic is covered.
-let primer dry
-apply paint, dont spray to much on at a time, do a thin layer every time, you dont need the desired coverage straight away (aka dont sit there spraying one spot) keep applying layers till the full colour is present and no plastic is showing from beneath.
-apply clear gloss the same as you did with the colour, except you wont need as much, but the more you put on the "deeper" the colour will look, and remember, dont apply to much in the same spot to quickly as it may run, you dont want this.
depending on the weather, it might be hard to get a glossy finish, if its hotter, the gloss will dry quicker and less glossy, so i recommend spraying on a cooler day, under 20c.
never spray when raining.
never spray after its been raining.
only spray when outside is completely dry, wait a couple of days if it has rained.
since its your first time, be prepared to screw up and start over., plastic IS NOT easy to work with.
and last but not lease
PREPARATION PREPARATION PREPARATION
if your un-confident with the preparation, give it another sand, or wax and grease wipe to be safe
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
