Power FC D Jetro and hand controller
Suit R34 GTR
$950.00
In adelaide. 0412 486 096
Matt
Hi how old is this? Ie how many km used in car. Does come complete kit? Ie 2 map sensors?
Edited by J_R32
Fc is not very old. Car has only covered minimal km since being built by previous owner and i have pulled it apart for total rebuild.
Includes map sensor etc.
  • 1 month later...
