I have a pair of Caliper Adaptors to suit someone running R32 GTR Non Brembo Calipers (296mm disk) and wants to run the 324mm disks (Brembo disks out of a 350Z). Purchased from Unique Autosports and only trialled fitted. These adaptors are modified to fit an S13, s14, s15, R32 GTST hub. They can also be used to run in a R32 GTR (non brembo)
Unique sell an adaptor to go from your standard 280mm disk to 324mm (using the cast iron caliper), but when going on a GTR Aluminium Caliper, they had to mill out a section to clear the hub.
Reason for selling, just bought new set of R888's on 16's, so don't want to spend another $2g's on rims and new rubber.
These bolt straight on and include all the hardware (caliper will need to be machined or filed slightly to fit larger bolt or you can get a smaller bolt) and if Melbourne based, I can throw in a set of 350Z 324mm disks that have been freshly machined and have 29.2mm of meat left of them.
This package cost me:
$350 for standard adaptors
$100 for machining and frieght
$180 for disks
$630
$350 and you can have the lot (pick up only or I can ship adaptors only at buyers cost)
Based in Melbourne
0409707054
Edited by sprint
SOLD SOLD SOLD
$180 for disks
$630
Based in Melbourne
0409707054
SOLD SOLD SOLD
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
