I have a dual A pillar Autometer 2 1/16" gauge holder and a 2 1/16" Autometer Boost gauge for sale. They are both brand new and still in the boxs.
Would prefer to sell the items together. I bought them through a friend at trade price (hence so cheap) and my boyfriend ordered the same parts from another shop (he didn't tell me he had ordered them). So to help this friend out, I'm trying to sell them for him to fix up my mistake :Oops:
The gauge = 2 1/16" Autometer Ultra-lite 30vac/30psi boost gauge - $130 SOLD
The pillar pod = Dual Autometer 2 1/16" black A pillar gauge holder. It is for a 2 door R33 GTR/GTST - $75 SOLD
I will not go any lower than these prices, they are already heaps cheaper than what autobarn rip people off with.
PM me for more details.
NB - These pics are of OUR guage and pillar guage pod we just bought, they are IDENTICAL to the ones for sale except the ones for sale are still wrapped in plastic :worship: Literally never even opened.
https://www.sau.com.au/forums/topic/33586-autometer-gauge-and-a-pillar-holder/
I'll get pics. My b/f took the digital camera last night. So I'll have to wait until this afternoon to take photos of them.
I won't go as low as $100. As I said, these gauges are already heavily discounted.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
