Hey guys and girls,
Selling my GoPro Digital Hero as I'm thinking of getting something else. I have only opened the packaging but haven't actually used the camera yet so it is still brand spanking new!
RRP: $175 from VSport
I'm asking $120 pick up from Hurstville.
PM only.
Kevin
Waterproof to 30 feet (10 metres) it is a convenient solution to shooting on the go footage of your friends and family during your favorite activities?be it on the mountain or in the water.
Originally designed for surfing in big wave haven, Northern California, the Wrist HERO is engineered for maximum convenience as well as maximum durability. Perfect for surfing or snorkeling, hiking or climbing, the Wrist HERO makes it easy to have a camera at hand for video and photo opportunities that occur at times when traditional cameras are too inconvenient to use or carry. No pockets? No problem if you are wearing the GoPro Wrist HERO camera.
Thanks to its patented design, the Wrist HERO can be worn securely flat on the wrist during your sport but can quickly pivot upright for aiming the shot. Even in this upright position, the camera is securely attached to your wrist. This makes it easy to grab your surfboard, paddle, or otherwise have both hands free without risk of dropping your camera. The housing is waterproof to 30 feet/10 metres.
The camera can also be strapped to gear such as kayak paddles and the leading edge of kitesurfing kites. This allows the kitesurfer to film looking down from above, as though they had a private helicopter camera crew following them while they surf.
The GoPro Wrist HERO has an adjustable neoprene strap that adjusts to fit a range of sizes from a child's wrist to fitting over the ski jacket sleeve of an adult.
The internal memory (32MB) stores 260-360 photos, or up to 32 10 second video clips.
VSport link
I also have a NEW GoPro suction mount for $45.
Edited by honki3rider
