Bomex style front and rear bar ------ $200 each
( have never been on car )
post-30023-1284183560_thumb.jpgpost-30023-1284183584_thumb.jpg[attachmen
t=304138:FRONT_BAR__2_.jpg]
GReddy turbo timer harness to suit full auto timer ------ $20
( will fit all rb25det engines with out having to hard wire timer )
Stock side mount cooler, shroud and a couple of pipes ------ $80
( Has small ding but flowed good on car )
Factory airbox and intake scoop ------ $50
https://www.sau.com.au/forums/topic/336405-stock-r34-gtt-parts-and-bomex-bars/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
