ReflextioN Posted September 11, 2010 Share Posted September 11, 2010 My car runs fine on low boost (7 psi) but on high boost (13 psi) it starts misfiring. Only mods are a BOV to atmosphere, Boost Controller and Exhaust. S1 R33 RB25DET. New plugs, coils look fine, AFM looks fine, could the fuel be doing this? Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/ Share on other sites More sharing options...
StealthX Posted September 11, 2010 Share Posted September 11, 2010 try gapping your plugs down bro. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5441731 Share on other sites More sharing options...
ReflextioN Posted September 11, 2010 Author Share Posted September 11, 2010 (edited) i dont think that will help because it runs smooth on low boost, and misfires on high.. is it easy to do myself? Edited September 11, 2010 by ReflextioN Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5441747 Share on other sites More sharing options...
97R33MSPEC Posted September 11, 2010 Share Posted September 11, 2010 gap your plugs mate. try em around .75mm with high boost is higher cylinder pressures, harder for the spark to jump. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5441837 Share on other sites More sharing options...
ReflextioN Posted September 11, 2010 Author Share Posted September 11, 2010 makes sense, ill try that, thanks. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5441941 Share on other sites More sharing options...
StealthX Posted September 11, 2010 Share Posted September 11, 2010 i dont think that will help because it runs smooth on low boost, and misfires on high..is it easy to do myself? ok then, don't take my advice. gapping your plugs should do the trick, but if not, then it may be your coils. Even though you ruled them out, try wrapping them in electrical tape so they don't earth on the head, sometimes the insulation wears out... Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5441958 Share on other sites More sharing options...
ReflextioN Posted September 12, 2010 Author Share Posted September 12, 2010 haha sorry mate i assumed that it should work regardless of boost, i didnt know higher boost affects the spark, but now i do Am getting it them gapped tomorrow and i will get the mechanic to double check the coils maybe ive missed something. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5442535 Share on other sites More sharing options...
StealthX Posted September 12, 2010 Share Posted September 12, 2010 haha all good bro For future reference, what's happening is the spark is too weak to jump across the gap in your plugs, and the higher boost level is 'blowing out' the spark, and misfiring. When you gap the plugs down the gap is smaller and the spark has a shorter distance to travel Good luck dood. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5442782 Share on other sites More sharing options...
defari Posted September 13, 2010 Share Posted September 13, 2010 stock ecu? if so, too much boost. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5444413 Share on other sites More sharing options...
Jezza-gtR Posted September 13, 2010 Share Posted September 13, 2010 haha all good bro For future reference, what's happening is the spark is too weak to jump across the gap in your plugs, and the higher boost level is 'blowing out' the spark, and misfiring. When you gap the plugs down the gap is smaller and the spark has a shorter distance to travel Good luck dood. Not 100% correct. The spark is not ''too weak'' the fact is higher boost is causing the engine to rev quicker so air veloicity is alot quicker and will blow out a large spark (big gap eg. 1.1mm gap). So yes a smaller gap (and spark) is used on turbo cars becuase of this reason. Cheers. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5444564 Share on other sites More sharing options...
StealthX Posted September 16, 2010 Share Posted September 16, 2010 Not 100% correct. The spark is not ''too weak'' the fact is higher boost is causing the engine to rev quicker so air veloicity is alot quicker and will blow out a large spark (big gap eg. 1.1mm gap). So yes a smaller gap (and spark) is used on turbo cars becuase of this reason. Cheers. Isn't that exactly the same thing I said, just worded differently? i.e. too much boost blows out the spark, cos the gap between the electrodes is too large, hence the spark is not intense enough to jump the gap before the air blows it out. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5450572 Share on other sites More sharing options...
ReflextioN Posted October 6, 2010 Author Share Posted October 6, 2010 (edited) Do i still need to gap the plugs if they are iridium? Im getting a new set tomorrow. Edited October 6, 2010 by ReflextioN Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5481957 Share on other sites More sharing options...
-_-StRyDeR-_- Posted October 6, 2010 Share Posted October 6, 2010 dont run iridiums... Do i still need to gap the plugs if they are iridium?Im getting a new set tomorrow. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5481996 Share on other sites More sharing options...
mad082 Posted October 6, 2010 Share Posted October 6, 2010 +1 for not getting irridiums. in my opinion they aren't worth the extra money. if you just get new plugs (even if you do get iridiums) that don't have -11 on the end of the part number then they should be pregapped to 0.8mm. Link to comment https://www.sau.com.au/forums/topic/336429-misfiring-on-high-boost/#findComment-5482165 Share on other sites More sharing options...
