Hey guys and girls
Im new to the forum and new to owning a Skyline, I have been checking the site out for a few weeks now and finally i picked up my 93 model R33 Series 1 today and I'm stoked, really clean car great mechanically and very clean interior, the guy i got it from had planned on painting the car matte black so he hit it with cans first to see how it looked :D anyway, lucky for me he only put a light coat over the gloss paint and I have a good mate that is a spray painter that will do the paint and body work for me at a great price. Anyway the car drives awesome with no apparent mechanical problems.
The Beast isnt heavily modded, but it has a front mounted intercooler, hks sequential BOV, exceedy heavy duty clutch, apexi timer and Saas sports wheel and gear knob and 3inch exhaust.
Anyway guys im super excited, i bought this as a project car and hoping to do some real cool things with this beasty. There are a few questions i have about R33's and my car in particular but i wont ask here i will leave it for the appropriate posts.
Just wanted to say its awesome to be a part of the Skyline community and I hope to meet some of you guys in Brissy one day soon.
Here are some pics of my car anyway.
Cheers everyone :)
Edited by nthside_skyline
https://www.sau.com.au/forums/topic/336459-newbie-from-north-side-brisbane/
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
