Thought they were same as R32, but Sleeka Spares in Adelaide is wrecking 2 Cefiro's at the moment if you can't find one locally.
I might have a very very clean one (the one in my resto build) very soon as well.
i've been told that they sit the motor lower then r32 ones? not 100% sure on that tho...? can you let me know if you'll end up having one for sale? but i'll keep looking as well. cheers mate
Rumours are they are different, yes.
For some reason, a Cefiro crossmember is NEEDED to do an RB20DET swap into an S1x so there must be some differences.
How's $150 + Postage / $150 + I drop it off to transport company and they ship it to you, COD
http://i37.tinypic.com/2qvy1hc.jpg
EDIT: Freight will be f**k all, since trucks go Perth -> Back over East with alot less on board.
Edited by Nic_A31
done mate! so with the COD i'll just pay the bloke that drops it off? whatevas easiest for u i can just give u money for the postage or whatevas. let me know mate
Cheers, Andrew
Yeah most mid sized freight companies allow payment on delivery.
I bought a FULL black interior (4x seats, 4x door cards, centre console, etc) from SA, the chick I bought it off simply took it to a depot, filled out con note and it was done, i paid for it over the phone when they called me to say it'd arrived at their depot (across the road from work) and picked it up later on.
IMO easiest way to freight big shit.
I went with Watsons Transport but ring around, get a quote and get back to me. I work in Perth's main industrial area, so most freight companies are nearby.
Give me a ring on 0431 598 320 when you've found your carrier, or if you need dimmensions/rough weight, etc.
would u be able to just box it up and post it and i'll pay whateva that cost is? the cross member shouldnt be to big to post. only cause i work out in the sticks and being near a computer is a rare thing for me cause i dont stay at home when i'm working.
Too heavy for a box, could maybe tie it to a pallet here at work but it'd work out expensive. Is why I suggested small/medium freight companies.
TNT/Star Trak/Big companies will charge through the roof for it as it's unpackaged and shit, little companies won't give a shit, they'll chuck it on top of another pallet and charge f**k-all for it.
It's your call dude.
too heavy for a box? i've spent and received a full set of coil overs before using auspost which were in boxes and which are the same weight if not heavier then a cross member? the one i took out of my sil wasnt that heavy??
Edited by A31Ceffy
Crossmember is still longer, and a bit of an odd shape.
Aus post wont accept articles over 1 metre long.
Might have to pull out of this sale dude - probably going to sell both of my Cefiro's immediately, and need the front crossmember to keep the shell rolling. I'll keep you posted.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
