Make: Nissan
Model: Stagea RSFour S-Tune (Only one of its Type known in Aust.)
Year: 2000
Engine: RB25DET Neo
Mileage 102,000km - Timing Kit and Water Pump just purchased
Gearbox: Auto - Tip Tronic
We are the first owners in Australia and have had this car for 3 years!
Engine:
RB25DET Neo – Plugs, Oil and Filter just changed
Stock turbo suspected to have had work done in Japan - Never run any more than 10 PSI Max!
Standard SMIC - Cleaned and flushed
K&N Panel filter
Chipped MiNes ECU - No Speed cut, fuel cut, advanced timing and redline upped to 7000rpm
3inch stainless exhaust from turbo - has high flow cat, resonator and chrome cannon
Cold Weather Pack - Heated windscreen, front seats etc.
Suspension: Bilstein Shocks and springs - Good in corners but soft enough for the freeways, under body brace also
Interior: Spotless interior with only a few minor marks (from Jap owner), Electric leather seats, Wood grain steering wheel and trims, power windows, Climate control, Dual Sun Roof's, Boost gauge, Electric fuel pressure gauge (safe to be in cabin), tool pouch with the factory Jack, Chock and Sunroof tool
Stereo: Fusion headunit (iPod/iPhone compatible) with fusion speakers
Exterior: Black over Grey (Only one known in Aust. with this colour scheme) Dayz Body Kit
Driveline: AWD - Gearbox and diff's oil changed at 90k. Suspected but unconfirmed gearbox work, possible after market shift kit.
Wheels & Tyres: Nissan 350z 18x8 with Near new tyres
Extra Details: Has factory HID's with new 6000k bulbs and still has working factory height adjustment
Starter motor replaced in 2008
New O2 sensor in 2008
Replaced axle boots
Large Marine battery
'Factory' strut tower and mirror rust repaired in April 2009
Rear cargo net and cover in the back as new condition
A set of Thule Roof Racks are also available as an extra, price can be discussed.
Insurance approved alarm/immobiliser
Jap earthing kit
This car does surprise as its quite quick and doesn't attract the 'wrong' attention.
6 months rego to be renewed in Oct. RWC won't be a problem.
Item Condition: Fantastic Condition, always serviced and parts replaced when needed. No accidents! Sub and amp not included in sale. Inspections will not disappoint.
Location: Ipswich, QLD but can travel for inspection (for serious buyer)
Reason For Sale: Change in lifestyle so time for an upgrade.
Contact Details: Via PM is Best
Price and Payment Conditions: $20k given it's excellent condition and only known 1 of its kind in Aust. If you have any other serious offers, they will be considered so please PM them. No time wasters.
Cash/Cheque - Not interested in any Swaps.
Edited by Whooby
https://www.sau.com.au/forums/topic/336752-2000-nissan-stagea/
  • Replies 43
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
