Board Message
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
Erreur Sphinx : searchd error: index ipb_search_topics: syntax error, unexpected $end near ''
Merci de contacter un Administrateur !
Got this weird board message today when doing a search.. I think it was from starting the search with a " - ". Just thought it was odd it was in French telling me the 'erreur'!
https://www.sau.com.au/forums/topic/336911-strange-board-message/
