that's fine for others to do but i wont ask others to lie on paperwork saying I'm only receiving so many $$$ of parts and trick the government out of tax
pretty sure they would send in separate parcels to keep it all above board
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5454974
  • Replies 92
Posted Images
you wouldn't have to change rails again Mark
and for injectors it depends on how much headroom your current ones have in the tune you currently have
Pete quite possibly, but someone else can organise it i got to much to do already thinks of @ least 2 events that need organising
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455089
feelings ey.... well im upset with life because..... oh feelings about e85. im sitting on the fence till it becomes more common.. not really down with changing rail and injectors just yet, already done it once :cool:
if its for the gtr then the top feed 1000's are around $600 delivered. and they use the std fuel rail. 1600's I think require the bigger fuel rail - you'd have to ask LukeENR34 if his 1600's fit into the stock rail - and theyre around $850 or something delivered
** depending on exchange rates, cc capacity, types of injector and impedance
-D
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455459
-D
dohmar can you get 1000cc side feed injectors for standard rb 25 rail?
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455480
no idea sorry - best to ask willall or any other tuner/member who actually runs e85 - i just run 98ron
-D
no worries will do, going to move to e85 eventually, probably purchase some injectors from you at some time in the future. Still in research stage at the moment.
https://www.sau.com.au/forums/topic/337085-e85/page/5/#findComment-5455566
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
