hey all
i just took my car out for a run through the nato park, soon as i went through the gates i pulled over to take a phone call, as the car was idling for afew mins, i could feel the revs slowly dropping, so i turned it off not thinking much of it.
restarted the car all was fine for another 30mins of non stop driving, then again same prob happened soon as im stopped idling and go to take off its like the engine wont rev at all, not missfiring, no nothing !
u have ur foot on the accelerator and it wont rev up ! sometimes it might kick back into life and the car boosts/idles perfectly again...
when this happens i have to quickly turn my car off, then restart it and away she goes all is good again
what can this be its driving me nuts !!
i had the car out last night and no such problem occured, and this morning i took my airflow meters off and cleaned them with some c02 contact cleaner. ive done this many times before so i dont no how this could have anything to do with it?
all AFm plugs are in tight, even checked the CAS connector and ignitior connector
any helpful info would be great !
thanks
https://www.sau.com.au/forums/topic/337371-r32-gtr-problem/
just disconnected the positive battery terminal pumped the brakes afew times and went for another drive, same thing, she doesnt like to idle at the lights and then to accelerate, without turning the ignition off and back on...
https://www.sau.com.au/forums/topic/337371-r32-gtr-problem/#findComment-5454305
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
