Hello All,
Due to an engine swap i have the following stuff for sale. All came out of my R34 with 76'ks on it. And all in excellent working order.
Im in Brisbane but am happy to arrange postage on the smaller stuff but you will need to arrange a courier if you want the bigger stuff.
Will sell as a package or separate.
RB25DET - 76000km's Complete minus loom inj/coil packs/turbo - oil change done 1000km's ago and always changed every 5tho. - $1500
Apexi Ax53B70 on a aftermarket low mount manifold - Inclds braided water / oil lines & dump pipe. - $1500
Nismo 600cc Inj - $550
Splitfire coil packs - $450
RB25DET Gearbox with Exedy Twin Plate Clutch - only ever run redline oil. $1500
This combo was making 240rwkw on 1 bar safe tune with awesome responce.
Looking for $4800 as a package. If bought as a package will throw in a HKS front mount with piping to suit.
Please PM for more details or can arrange photos if needed.
Edited by ls1ben
Few pics below. Turbo has zero shaft play/fins perfect and overall excellent condition.
Engine does come with a/c & p/s - only took it off for easier removal.
Yes i am. I have had a few pm's about it. once i remove the box ill get some pictures up and will be open to offers.
Also, coil packs are sold!
Is the injectors to suit rb25det NEO? I thought Nismo only made 480cc injectors for the NEO.
How much would you be looking for the HKS intercooler kit? And the exhaust manifold? Anymore info on manifold?
My apologies, Yes they are off a NEO so they must be 480's then as its still stock fuel rail. I wasn't sure and just saw that they were purple tops and googled it and found that 600cc are purple but now I see 480cc neo's are purple too! Thanks for pointing that out!!
So - 480cc Nismo NEO injectors - $550 make an offer!
I have a bit of interest in the kit so wont split the manifold and turbo at this stage. But ill let you know if I am willing too.
As for the cooler kit. Ill organise a photo and you can make an offer. Not sure what its worth.
Thanks Jin, Enjoy!
Sorry about the delay on intercooler pic. Here it is. make an offer?? There are a few more silicon joins with it as well.
Everything is sold except the turbo on the manifold with dump.
Thanks Jin, Enjoy!
pm me lowest price and dimensions mate very keen :P
p.s is it direct bolt on for r33 gts t rb25det..
cheers
  • 4 months later...
  • 2 years later...
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
