Hi guys,
Ive got a good condition HKS EIDS, Electronics Idle Stabliser. Its helps to solve the low rpm stalling problem that people get. Basically it adjusts and slows down the rpm drop when the accelerator is released. Especially helps those with BOV that vent to atmosphere.
Still have the special splice plugs unused that are needed for install.
Retail is about $175, so make me an offer
Id be happy around the $100 mark
thanx
will
p.s also still got 2xr32 gtst guards LH and RH side in perfect condition unmarked gunmetal grey, 2xr32 GTR front section of skirt in both original and fibreglass, r32 gtst bonnet clip and bracket.
https://www.sau.com.au/forums/topic/33746-solve-stalling-with-hks-eids/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
