For sale is a bt1 vl sl
Original white
Original a8 block
T3/t4 high flowed turbo
Microtech plug and play lt10s with hand controller
3200 rpm stally manulised jatco box
Included in sale is B&M pro ratchet shifter in box new
Auto meter guages
Lowered
Tinted windows
$7836 of recepits just for the head work
On interceptors
Big front mount tucked behind bar sleeper look
Dyno sheets for 166.1kw & 920 nm
More things just can't think atm
Bad points
No rego
3x small rust spots
unis need doing have them just haven't got round too doing it
Car is at harrington nsw. I live in newcastle so have too arrange time too have a look
Contact jahn on 0432163488
$8000 maybe swaps really want cash heaps more just I'm not near the car so can't remeber everything
Pics up soon as possible
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/
post-75643-1285375337_thumb.jpgpost-75643-1285375289_thumb.jpgpost-75643-1285375261_thumb.jpgpost-75643-1285375236_thumb.jpgpost-75643-1285375201_thumb.jpgpost-75643-1285375201_thumb.jpgpost-75643-1285375156_thumb.jpgpost-75643-1285375114_thumb.jpgpost-75643-1285375114_thumb.jpg
Original white
Original a8 block
Auto meter guages
Lowered
Tinted windows
On interceptors
Bad points
No rego
3x small rust spots
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5464951
how many k's on it mate?
Not exactly sure but the motor and driveline are all rebuilt supposed forged bottom end and fully built head have recipts for all work
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5481188
$7500 mods done too this are worth way more just needs wastegate actuator mod then bump the boost up genuine bt1 all matching numbers supposed forged bottom end no recepits but
https://www.sau.com.au/forums/topic/337593-vl-bt1-turbo/#findComment-5497775
  • 1 month later...
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
