anyone go to the summernationals yesterday or today? just got back from todays events and damn it was fun. 95% of the entrants were sub 10 second cars and by the end of the day an 8 second pass seemed relatively slow.
the highlight had to be the top fuelers. unfrickingbelievable! these things are scary fast. best time was a 4.8 @ 309mph by the rocket car. i'd never seen one run up close and the first time they flew past my hands just slapped my ears shut before i knew what had happened. you can feel your balls retreat inside your stomach.
track is run very professionally and looks like everything it was promised to be.
https://www.sau.com.au/forums/topic/33772-summernationals/
I went last yesterday arvo/night. I have to say i have never been a huge fan of drag racing until now. The highlight of the night was by far the Top Fuelers and as Two40 said, unfrickingbelievable!!@@!#!#!@. I have seen indy cars, f1 cars GP bikes everything but i have never experienced anything like the top fuel dragsters. Sitting half way up the hill i felt my hair been blown around and the heat hitting my face as they took off and my internal organs been shaken like they have never shaken before. Seeing the cars reaching just off 500kmh at the end of the 400m side by side has definatly turned me into a drag racing fan although i will always be a bigger circuit racing fan. The rest of the cars were good and as said before anything over an 8 second pass began to seem slow.
The other thing is the WSID is an excellent facility. We will be very lucky to have a facility like this in sydney which runs weekly street meets. The night also showed me that australia has alot of depth in drag racing. Although there are only really 6 top fuelers the rest of the classes seemed fairly full and the workmanship of the cars was awesome. (you were alowed to walk through all the pits, bloody good). Anyway. I had a great night and will be attending as many major events there as i can.
https://www.sau.com.au/forums/topic/33772-summernationals/#findComment-678110
went on sat arvo/night
was awesome, yes those top fuellers are amazing
the ground shaking, your vision blurred, your ear drums rattling and seeing something go from 0-500km/h in 4.8sec over 400m is the a must see
great facility, still being worked on in terms of crowd facilities etc, but going to get better and better
and from the crowd, drag racing is back in business in sydney
https://www.sau.com.au/forums/topic/33772-summernationals/#findComment-678532
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
