I bought this last friday, to replace my impreza, which will fund a work ute
its clean as, auto :-( , and a tight and responsive L24e $850 with 2 months rego
I have 2 5 speeds and a spare L24e from a C210. I was wondering if anyone has
everything else to convert to manual (pedal box, clutch master and line, stick,
console rubber and floorpan seal) and if the yoke is the same with auto and manual
feels good to be back in a skyline, any help is appreciated
https://www.sau.com.au/forums/topic/337928-my-new-daily-drive/
damn.
thanks guys for your help
there is a datsun wreckers in Castlereagh, Sydney, that has a straight C210 coupe
minus engine, gearbox and most of interior if anyone wants it. Has rust in boot, but is worth saving. also 2 MR30 sedans
His name is Carlos, he's a reasonable bloke, have a chat to him
http://www.sportsclassic.com.au/
^^^ Carlos Casmiri ^^^ Rally dude and hoarder of Zed Parts.
You need the tailshaft and speedo cable from the manual, as well as the clutch pedal and the bolt/rod thing that goes through the manual pedal box...
I reckon that, the Auto and Long Manual box would be the same length (didn't measure) so you might be able to use the Auto Tailshaft with a Long Box... but the gearstick will be a few cm further back in the hole...
Biggest problem is going to be the crossmember... the Auto Tunnel is about 10cm wider than the Manual Tunnel, so you are trying to bolt the gearbox crossmember into thin air... Auto one crosses the transmission in a completely different spot, and bolts through the floorpan at different levels, so you will have a slight complex fabrication job...
Cheers,
Daewoo
heeheehee i like that
Im hoping to find a complete manual at the wreckers. nothing in sydney, goulburn has a couple of auto's. i will find one!
thought that would be the case with the long box, so i wont use this option.
Ill be able to fabricate the crossmember no worries. I think my biggest drama will be getting hold of the complete conversion.
This is all very useful info, Thanks daewoo, muchly appreciated!
When you do, can I have one :(:rofl::D ... all progress on mine stopped about 3 months ago when I hit this hurdle, and lost interest... as the teachers all said "Daewoo is easily distracted"...
Two things... the short boxes are in short supply, only ever used in MR30s and Stanzas... and, the plate that holds the input shaft bearing (or whatever it's real name is) is Aluminum, so prone to shitting themself... before I bought it, I would be taking that plate off and seeing if it is faxed, if it is, the plate is the same as a 'K' box, but it usually faxes the whole front housing (which you can also just swap for a 'K' one)...
As it is just a Daily, probably not a big deal...
Cheers,
Daewoo
Edited by Daewoo
Rushy (Pick n Payless) at Blacktown doesn't have any ?????????
Take a drive down to Dapto Pick a Part, they have 5 MR30's down there and I think 2 were manuals complete when I was there last Thursday.
I wasn't looking for manuals persay, but will if you like as I should be down there this week after picking up my manifold from a guy nearby. (Extreme Turbo Manifolds)
Cheers, D
Dapto don't know what they have!
Last Thursday they told me they had ONE (1) but I found FIVE (5) so maybe the four (4) they don't have are manual lol
I'm going back to Extreme Turbo Manifolds on Thursday morning, so I will stop in to Pick a Part and look. If I find I'll take some pickies for you as proof.
Cheers, D
Ok! Been to Dapto today and as usual, they don't know what they have and there was one manual, but the pedal box was being removed when I was there and the rest had gone, if the guys taking out the pedal box already didn't have it.
PM me with what you need for this manual conversion and I'll see what I have spare.
Cheers, Dennis
thanks for that ghostrider. wreckers people are generally pretty dumb, like the guys in Melbourne,
crushed the C210 coupe after having it for only a week and everyone wanting stuff off it
Mag86, i need the whole lot, seeing as the C210 5 speed is too long
Do R32 gtst's use a stubby box? i know is a lot smaller than the R33 box.
had a thought, RB25 n/a and a R32 box. what do you guys think?
Also bought a DR30 series 2 instrument panel, techo goes to 9000!
but all the connections are different to the stock instrument panel.
ill upload a pic asap
Your going to have a problem fitting your S2 instrument cluster into an S1 car. All your connections are diferrent, so you're going to have to rewire or maybe replace the instrument loom. Don't know if the latter is possible, but rewiring would be.
The R32 box can be used but it needs an L series front housing on it. As Mags says Stewart Wilkins will do the mod for you. The gear lever is going to come out of the tunnel a little further back in the hole, which isn't a huge biggie issue.
I was originally going down the RB25DE conversion until I stumbled across my PNV and decided to keep it a bit stockish. It's a relatively easy conversion and been done to bits, along with the RB30E conversion.
I'm about to have a huge cleanout of accumulated bits, so if your interested let me know.
Cheers, D
This is what you want if your going to do it easy!
http://cgi.ebay.com.au/Nissan-DR30-Skyline...=item58867ab14f
If you buy this, take it to South West Instruments at Smeaton Grange and he will modify it for you. He did my S2 cluster a few years ago.
Cheers, D
Yo! here is my instrument cluster
I like how yours goes to 260km/h. ill think about that one
that cluster itself will justify a engine transplant :-)
The series 2 dash KILLS the series 1 dash!
thanks andrew, good info!
engine exchange isnt a huge priority at the moment
might do it in 6 months or so
ghostrider, when you do your clean out, if you can gather a
complete 5 speed conversion, including tailshaft,
and also series 1 hotplates in good condition. If you have
all this, and we can talk price.
thankfully, you dont live too far from me
I read somewhere that for ideal air supply, the plenum
volume is matched with engine displacement, and double engine
displacement for n/a engines. cut 3 sides off the stock plenum
smoothen the inlet runners and tig up a 2.4l volume plenum.
dont know if im dreaming now, but a RB30 throttle body and airflow meter
to a aftermarket ecu?
The 260km/h speedo is very difficult to get these days, as Jenesis wont trade outside of the domestic market. One sold on ebay (complete cluster) recently for a little over $200.00 and the Tomei variety 240km/h gets onto Yahoo in Japan a bit often but landed it would cost in excess of $600.00.
When you look at the back of the S1 cluster, you will find it entirely diferrent to the S2.
I might have an Aussie S2 dashboard harness in a grey dash under the house that you can play with if you like. I'll have a look over the weekend and let you know.
Mechanical parts I will be reluctant to let go because I have 2 x KHR30 Paul Newman coupes & an DR30 coupe track car that need maintaining. A stock tailshaft I might have, as I'm upgrading one of my PNV's to the stronger larger DR30 tailshaft. The companion flange might be an issue because all my R30's came out with R200 diffs.
Probably the only box I have that I would be prepared to let go is an HR31 RB20DET box.
The RB30E throttle body isn't much better than the one you have now. The next one up is the 60mm KA24E (U12 Pintara) or RB25DE throttle body and with an a/mkt ECU you wont need an AFM at all, as it will most likely use an MAF sensor.
As for an inlet plenum, you might find it's more cost effective to extrude hone or power port the manifold. I have an N42 (non EGR) 280ZX inlet manifold that has been comcoated, that I might be tempted to part with, or maybe a stock 280ZX EGR manifold, depending how your bent.
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
