thought Id add my sh*t heap, got it for jack, and spent about 3 months fixing and replacing everything just to get a roady, hardly anything worked on it, but everything does now
so it did have a torque monster RB20de/auto, up until today, to be replaced by a 20det + 5spd,
so here it is
https://www.sau.com.au/forums/topic/338132-my-aids-a31/
  • Replies 57
sweet! was that you? I got a fright, now heres something ya don't see everyday 2 cefiros in a row, mines a 91 model so I was stoked it had the s2 lights.
I/m just about to put the motor/box in today, did all the manifold studs yesterday, and I almost have everything for a 4pot 5 stud conversion
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5466028
yeah ive seen urs twice, mine is a family car with a pretty healthy rb25. If you need a hand with anything ive done all my suspension (32 cradle, 5 stud, coils. etc) Im only 10mins from mt ommaney.
sweet! yer I may need a hand if I don't sort out my power steer line issues, might need to have a look at yours, Im in Bogan Logan
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5466935
lol currently i have no power steering, trying to source the high pressure non hicas power steer lines but no one seems to have any, my little tiny missus has arms like hercules now. Alot easier with 205 on the front rather than 235 previously.
Logan aint to far. Im just off johnson road.
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5466940
leather seats? :down:
I wish I could have grabbed them, they were there but that car was in New Zealand, I just brought back the door trims and a big box of spare parts
Just to add since I'm from NZ cefiros/laurels are so common that they are worth nothing, 70% of the laurels are diesels, wreckers get them take some parts off them then crush the rest! :ermm:
the series 3 cefiro I got the door trims off of was a mint running 1993 2.5 SE, the wrecker paid $250 for it! it failed a roady for a leaking P/S pump and the owner just wanted it gone
that sort of shit happens day to day there since 50% of the cars there are imports never thought about it until I moved here and im now cringing,
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5466957
theres a 2W steer A31 at ABC wreckers, last time I was there just the ps pump was gone
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5466962
Just to add since I'm from NZ cefiros/laurels are so common that they are worth nothing, 70% of the laurels are diesels, wreckers get them take some parts off them then crush the rest! :down:
how hard/easy is it to get stuff shipped from nz??
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5467007
If you end up getting rid of that auto centre console to go manual and have the surround (top bit), let me know. I might even have a manual centre console + armrest you can have in exchange.
I do, I have 2 auto gear stick surrounds (which will only fit series 2 and 3) and I was going to modify a R32 console I have, but if you have the factory stuff that will fit mine, deals on!
https://www.sau.com.au/forums/topic/338132-my-aids-a31/#findComment-5476686
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
