Hey, I've had this stuff sitting in my shed for awhile plan was to build a mental motor but an old car of mine is up for sale and I'd like to buy it back. Sooo these have to go.
Parts where purchased from Paul Diemar or Red R Racing and the setup was discussed with him and in his words was the best/toughest setup for a RB25
It consists of:
CP Forged Pistons 20thou oversized (86.5mm) with gudgeon pins and brand new rings - Note pistons are used but almost new removed from motor due to engine failure of some sort, Had them checked out thouroughly from a reputable engine builders he said they were mint and almost new condition.
RB26dett rods machined to suit rb25det, these have been known to take well into 700whp and Paul said that he favoured these rods over forged rods. Fitted with ARP 2000 Rod bolts
ARP headstud kit- complete to suit rb25det/rb20det
I am only looking to recover my losses to fund new project.
$1700 ono - will post anywhere at buyers cost. PLEASE DONT HESITATE TO MAKE ME AN OFFER. WITHING REASONABLE AMOUNT!
Pictures on request.
Cheers
https://www.sau.com.au/forums/topic/338386-big-hp-rb25-setup/
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
