I'm trying to figure out the differences between the R32 GTR and GTS-T in regards to the front axle set-up. I have the FSM for the R32 GTR and posted the picture of its front axle here Is the R32 GTS-T's set-up anyting like this. Of course it wouldn't be 4wd but I was thinking that maybe the upper links are the same...etc. Please give me some input. Thanks.
https://www.sau.com.au/forums/topic/33888-difference-between-gtr-and-gts-t/
well my car is having the whole front end suspension re-built pretty much as i'm changing everything I can at the moment to improve handling. That diagrams looks *very* similar to the GTS-T. One thing that definately does seem diff is the cross-member.
There will be other small differences but the basic setup should be the same.
Hi deorbit, the GTST has more caster than the GTR as it is limited due to the four wheel drive requirements. The upper suspension mounting points are in exactly the same positions on the chassis. So the only way Nissan could get the caster difference needed was to have different lower control arm inner mounting points between 2wd and 4wd. Hence the sub frame is different. The shocks, springs and stabiliser bars are the same physicaly, obviously the rates are different though.
If there is something that I have missed that you would like to know, please just ask.
thanks for the info man.
Also i'm gettin adj. upper control arm bushes put in place to adj. camber. Also getting adj. castor rod buses as well. I was asking about replacing the upper control arms and castor rods to improve handing but the place where the car is at just said to get the bushes as its not worth getting the whole hog. This correct?
Is the chassis (apart from the flared guard) of a GTS-T and GTR identical. i.e could the running gear of a R be transplanted into a T without major mods?
That would be very interesting to know deorbit.
If there is the possibility it being a simple bolt up of the GTS4/GTR front running gear to be transplanted in to a T I may look in to the $$ involved and see if its worth while doing for the new motor.
I need a new gearbox anyhow.
I don't know about the others but I may look at bolting up a GTS4 or GTR FWD depending on difference (gearbox strength at ~300rwkw).
the front crossmember would need to be changed and it mounts up differently to the gts, also you would need to belt a large dent in the floor pan for the transfew case to clear. it would be possible but fot the cost of 89 gtrs, its not worth the hassle. Get the chassis sorted and use the better handling and lighter weight to your advanage, just need good tyres
Hi Joel, RB25DET, as in R33 GTST, gearbox is the same internally as an R32/33 GTR gearbox. I tend to think they would handle more power, as the traction would not be as good (4wd versus 2wd) plus the weight is much less (R32 GTST versus R33 GTR).
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
