>>-------- - - - - - - - SAU Member's ONLY promo - - - - - - --------<<
>--- - - - - Special Price $50 Members / $65 non-Members - - - ---<
Pro shots of your car in a great locale! Get in quick!
Only 9 time slots - First in and reserved.
We've secured a photo shoot location at the Edge Theater and have Kory (FST513) and Matt (MaTBoy) doing a mini photo shoot of your car on location.
How it will work:
Reply in this thread as your reservation books you a 10 minute "mini photoshoot timeslot". Make sure you list your car's model so we know which cruise group you'll be arriving in.
On the day of the cruise BE SURE you make it up to the Edge with your cruise group or you might lose your time slot.
On the day bring $50 and meet the photographer assistant in the Edge car park right in front of the theater. We'll have a few car stalls reserved for people waiting for their timeslot for the photo shoot.
When you're up, you'll position your car in the 'alcove'. Then let the photographers do their thing!
They will be doing some post production touch up on the photos so we will mail them out to you within a few weeks.
Want hard copies? No problem. Photo quality printing services will also be available for an additional charge.
These are some of test photos to give you an idea of the location and what you'll get
(Our Photographers will be bringing their lighting equipment to ensure you get pro quality shots on the day):
https://www.sau.com.au/forums/topic/338899-mini-photo-shoot-21st-r32-cruise/
What a great idea! Can I come spectate? Kory's a hella good photographer. Good luck guys!
Cheers, thanks Rallye :laugh:
Of course you can come spectate. I'd offer you a lift, but you live way too far away from me lol and completely out of the way for where i have to head first. Sorry mate!
Well, with the chance of a shower I can certainly understand people's reservation on stepping up for this one.
The photographers will be on the cruise but will only set up the photoshoot if conditions are good. If you are interested see me on the day.
Here's my mug shot:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
