for sale, pick-up prices, need it gone:
2x z32 6-pin afm maf plugs wire harness, suit gtr rb26 - $20 for the pair (+ $5 post)
2x z32 afm plastic adapters, connects z32 afm to pod filter, $30 for the pair (+ $10 post)
2x rb26 gtr standard afm maf sensors, good condition - $120 for the pair, no plugs / wire harness (+ $30 post)
1x z32 afm maf sensor, professional repair fitted with 5-pin for rb20/25/30 for plug'n'play installation, part# N62 A36-000 22680 30P00 - $100 (+ $20 post)
r32 sedan rear seat set, blue/grey excellent condition - $20 need it gone or will dump
r32 sedan rear spoiler wing with brake light, grey good condition - $20 need it gone or will dump
r32 gtr dba4000 slotted discs, 297mm, 98% new condition, trial fitted years ago sat in shed since, $200 for the front pair. (+ $50 post)
c34 stagea series 1, front slotted discs & front stock discs, used condition, $100 for the lot
c34 stagea series 1, front 2-pot brake calipers, 2x sets of front bendix pads, calipers fitted with 20cm-long braided stainless steel banjo brake line, comes with caliper rebuild pack, $100 for the lot (+ $40 post)
c34 stagea series 1, drivers steering wheel with airbag, excellent condition - $80 (+ $40 post)
c34 stagea series 2, tiptronic auto controller - $60 (+ $20 post)
c34 stagea series 2, drivers steering wheel with airbag & tiptronic controls, excellent condition - $100 (+ $40 post)
https://www.sau.com.au/forums/topic/338919-skyline-stagea-parts/
z32 afm SOLD pending payment
for sale:
1x HKS EVC-3 electronic boost contoller, complete setup with harness wires, unit, solenoid - $150
1x 240sx S13/S14 12.75" 324mm brake bracket adapter setup, suits 350z front discs & 300zx calipers on Silvia - $150
